EAGLE User Support (English) Question about thermal relief (spoke) widths
  • Views 1695 views
  • eagle
  • thermal_relief
I noticed that thermal relief (spoke) widths are same for 0805 and 0603, about 20 mils.
For SOD-323 they are about 11 mils.
The width of GND polygon where they connect is 10 mils.
Is that how it is supposed to be? How Eagle decides that?
Thanks.
    Yes, that makes sense.
    Thanks!
    Warren Brayshaw wrote:
    >> 0603, about 20 mils. For SOD-323 they are about 11 mils.
    >> Thanks.
    Search for "Thermals" in the manual.
    In essence the spoke width is 25% of the drill diameter of the pad.
    but between 1 and 2 wire widths of the polygon.
    For a SMD I believe I read somewhere that it is based on the smallest
    side of the SMD.
    Apologies, an error previously
    Spoke width is 50% of the pad drill diameter or the smallest side of SMD
    with a minimum width of 1 polygon wire width and a maximum of 2 wire widths.
    Warren
    news.cadsoft.de
    On 1/7/2013 4:40 AM, Rahul Swaminathan wrote:
    I'm not too sure about this, but I think you can change these in the DRC window. Does it really matter for your application though? For things like 0603 resistors and caps, it doesn't make much of a difference, but with DC power jacks, I've noticed that the default width generated is too thick, and I have trouble soldering the ground pins on.
    Hi Guys,
    The thickness of the thermal relief spokes is determined by the width of
    the polygon. So if your polygon width is set to 10 mils your spoke
    traces will have a width of 10 mils.
    hth,
    Jorge Garcia
    Cadsoft Computer
    Thanks.
    In essence the spoke width is 25% of the drill diameter of the pad. but
    For a SMD I believe I read somewhere that it is based on the smallest side
    of the SMD.
    Warren
    news.cadsoft.de
