EAGLE User Support (English) How to access layer 50
  • Views 779 views
  • layers
I am trying to generate a IDF file using the generate_3d_data_v10.ulp and I keep getting an error. The error is that I do not have a board outline defined in layer 50. however when I go the board layout and create a polygon for my outline I cannot see layer 50 on my list of avialable layers. I only see layers 49, 51,52 at the end, layer 50 is absent.
Any ideas why its missing?
    Thank you for answering my question
    Felipe Godinez wrote:
    absent.
    That's normal. its an unused layer
    Make it usable.
    In the package editor command line type
    LAYER 50 BoardDimension3D
    You then have  a layer 50 named "BoardDimension3D"
    Make the name whatever you like.
    There are other layers you will need to provide data into.
    Open the ULP in a text editor and reference the notes near the top.
    There is a link to a PDF you will need to read
    Good luck
    Warren
    news.cadsoft.de
