EAGLE User Support (English) Ultralibrarian import problem
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 1287 views
  • ultra-librarian
  • library
  • script
shseidman
shseidman over 13 years ago
In Eagle 6.4, I'm getting an error rmessage "Parameter 'rank' is only valid in board editor" when running a scr generated by Ultralibrarian (free version) from the microchip site, on the file  MCP1700X-XXXXX_MB.bxl.  It seems to stop before generating the polygon for a thermal pad.  Any suggestions?? (Couldn't upload bxl file)
    ""This problem has been tested and is correctly working with version
    5.3.320.  You can download the latest software directly from Accelerated
    Designs at www.accelerated-designs.com/Beta/ULADI_Reader.exe"
    You can use the UL FREE reader to download parts from TI, MicroChip and
    others.
    On 19/01/13 01:34, Warren Brayshaw wrote:
    Scott Seidman wrote:
    >> Thanks! Thought I'd try a little shortcut, and it didn't work out so
    >> well. I guess it's not worth their time to maintain the freeware.
    >> Maybe I'll try running the script in v5.
    It will still have the same problem in V5. Ultralibrarian has the problem
    Indeed. When I saw that Microchip claimed to have Eagle libraries for
    most of their parts I was very pleased. When I saw the horrendous
    garbage that so-called "ultra" librarian generates I dismissed the claim
    as utter rot and went on making my own libraries as always.
    Cheers,
    Rob
    0 e14 Contributor over 13 years ago in reply to shseidman
    You may be interested in this, which was mentioned  here recently.
    http://www.pcblibraries.com/
    All the best
    Warren
    news.cadsoft.de
  • shseidman
    0 shseidman over 13 years ago in reply to e14 Contributor
    Thanks!  Thought I'd try a little shortcut, and it didn't work out so well.  I guess it's not worth their time to maintain the freeware.  Maybe I'll try running the script in v5.
    I'm actually running it in the library editor, where the instructions
    specify
    OK, I've had a look at the free Ultralibrarian program you mention and the
    script file it generates for the MCP1700X-XXXXX_MB
    In a word, unimpressive.
    Looking at the script produced I can see the problems you are having and
    others you may have.
    Your reported error is because it attempts the following line in the package
    editor.
    Change rank 0;
    Which is illegal in the package editor. Remove the line and the script runs
    to completion. But........
    The next  issue is the polygon it attempts to draw. It does not end up at
    the starting point so the polygon is rejected by Eagle. (never drawn).
    Add (-12 -52) to the end of the polygon line (just before the image that will
    get you back to the beginning.
    So that draws the polygon now but there's another issue
    The polygon  does not extend to include the origin of the centre SMD so you
    will get DRC errors unless you manually extend it.
    Drag the bottom of the polygon down below the centre of the SMD.Its a bit
    concealed by the SMD but you can see where the bottom is because the SMD is
    a little wider.
    If you have trouble, turn off all layers except layer 1Top
    Ultralibrarian is an old program and would not know this is a requirement
    for Eagle v6.
    Numerous  (7)  text objects are placed on top of each other. Took a bit of
    working out what was going on there. Just drag them apart.
    So there's the answer. HTH
    Warren
    Viewed / responded at the newsgroup at
    news.cadsoft.de
  • shseidman
    I'm actually running it in the library editor, where the instructions specify
    Seems you may be running the script from the Schematic Editor, try running
    it in the Board Editor
    Warren
