EAGLE User Support (English) Licensing Eagle, Work and Home
  • Subscribers 189 subscribers
  • Views 446 views
zainka
zainka over 13 years ago
We are using eagle at work and offcourse have a full fledge license with all its flavours to use for our designs here. However, at home, for my own private hoby projects I have been using a Non Comercial license as it suits me perfectly.
As I now have a laptop from work that I am also allowed to use at home, i will sometimes use this laptop rather than my own to work on my own designs when i am traveling. I also use git so that i can work on my designs on diferent PCs If i liked to
All my private projects followes the limitations in the non comercial licensed version. However, Is there any danger to continue for example routing on my works laptop and then switch back to my local machine later?
I use the same version, today that is eagle 6.4.0, in both environments so that would not cause any problems, and all changes is after each session pushed to the git server. The only fear I have is that the two diferent licenses could interfere in some way that is dificult to detect.
Breg
Vidar (Z)
    0 e14 Contributor over 13 years ago in reply to zainka
    On 2/18/2013 7:02 AM, vidar vidnes wrote:
    Guest wrote:
    You worry too much.
    It keeps me alive....
    http://www.element14.com/community/message/70001#70001/l/re-licensing-eagle-work-and-home
    Hi Vidar,
    I hope you're doing well. Don't worry you shouldn't experience any issues.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
  • zainka
    0 zainka over 13 years ago in reply to e14 Contributor
    Guest wrote:
    You worry too much.
    Breg
    Vidar (Z)
    http://www.element14.com/community/message/69944#69944/l/licensing-eagle-work-and-home
    You worry too much.
