EAGLE User Support (English) Lost Switch Symbol I Built In Vsn 5.12
  • Views 440 views
  • microzed_iiot
I recently built a switch and used it in a pcb layout.
Now I cannot find it either in or out of XP compatibility
mode. Want to use the switch in another design. It still
shows in one of my designs but the library is gone. The switch
was not designed in XP compatibility mode. I have done a Windows
search for the library TL3310. Cannot find it. My system Dell Vostro
470 3.4GHz, 4 GB ram, Win 7 Home Premium. Help please.
    Yes, you have been "helped" by windows.  The trick in this case is to
    create a folder under your documents (or other place you have write priv.
    to) for your own libraries etc.  Then, in Eagle, you add the path to your
    libraries to the preferences so it looks not only in the installed libs,
    but in your custom libs as well.  This will also prevent Eagle from
    overwriting them when you install a new version.  See the "Options ->
    directories" section of the user manual in section 4.1 for how to add
    additional locations for your libraries etc.
    mikey
    On 1/24/2013 1:00 PM, Bankole Paris wrote:
    I found the file here:
      Files/Eagle 5.12/lbr/TL3310C:/users/bdd4/AppData/Local/VirtualStore/Program Files/Eagle 5.12/lbr/TL3310
    Why ?
    Google UAC Virtualization in Windows 7.
    hth,
    Jorge Garcia
    Cadsoft Computer
    Why ?
    You can run the EXP-LIB ulp and retrieve the part.
