EAGLE User Support (English) EAGLE: Name of object?
  • Subscribers 189 subscribers
  • Views 477 views
  • eagle
  • schematic
I'm quite new to EAGLE, and want to learn to do something, but don't know its name. All I can do is describe it.
I have a .sch file that I want to put in a bigger, system-level .sch file. However, I don't want to just copy (excuse me, cut) and paste it, I want to put my little .sch into a nice package (a rectangle with pins on it) so that the system-level .sch isn't as cluttered. In other CAD software they're sometimes called "modules", I think.
So I've attached a picture of what I want the end result to look like - this particular one is an Arduino Mega, which is full of stuff, but has been made into a nice little package, so that it can be put into a higher-level schematic.
Does anyone know what I'm talking about?
Felix
    the way I've got around this problem is to simply create a library object with the correct outline and pin positions as the module.
    You can then use it easily in different applications.
    hope that helps.
    ian
    0 e14 Contributor over 13 years ago in reply to Morosh
    Hey Morosh,
    Thanks for the tip - I'm gonna try and figure it out tonight.
  • Morosh
    0 Morosh over 13 years ago
    On 25/01/2013 00:54, Felix Kong wrote:
    Felix
    check "http://www.cadsoftusa.com/downloads/file/hierarchical_v10.zip"
    HTH
