EAGLE User Support (English) Problem with component inter-sheet
  • Views 438 views
  • sheet
  • eagle
  • bga
  • schematic
  • component
I work with Eagle 6 pro and I have a problem with a component.
I made in my library a BGA with 180 pins. For more lisibility, I separe the power and the peripherals pins on my schematic.
What I would do is a part of my component on one sheet and the second part on a second sheet. (Like a Altium schematic)
How is it possible ?
Thank you very much.
Jonathan
    Nice, the command line solution is working. But the drag-and-drop no. But the problem is resolved with the first solution.
    Thank you
    Jonathan
    On 27/01/13 11:24, Jonathan Rifaut wrote:
    There are two ways to do this.
    The "traditional" (works on Eagle 4) method was to use the "invoke"
    command. Either set up all the bits of the component (the symbols in the
    library device) as "on request" or "next" bits or delete most of them
    from the sheet where they all appear when the part is placed. Then on
    the other sheets do "invoke ICnn" (you need to type this in the command
    line because there's no gates to click on for selection) and pick the
    bit you want on this sheet.
    Since Eagle 5 it has also been possible to drag-and-drop gates of a
    device from one schematic page to another using the thumbnails down the
    left side. I don't know the precise semantics, though, because I'm still
    using 4.16
    HTH
    Rob
