EAGLE User Support (English) Bus labels
  • Views 331 views
Bus labels
When I use a BUS label the label is showed as "LABEL:net1,net2,etc".
Is there a possibility to show just the bus name?
Wim
  • i_droppa
    0 i_droppa over 13 years ago
    you have to use the following form when you want to add a name to a Bus:
    Label( 0 . . n )
    "Label" the name of the Bus,
    "n" is the number of the wires minus one,
    you have to use two points between the numbers.
