EAGLE User Support (English) Changing Layer of a bmp?
  • Views 1020 views
First post, please be gentle.
I have used a library from http://lucidtronix.com/tutorials/20   and added it to my board.    ive used mirror and it displays underneath.
When I upload the file to OSH park, the picture on the screen is not shown..but the writing is..
all the text on layer   22 is shown
the picture is on....22
how to I make it show, can I change it layer .. and how.
cheers
david
    The bmp needs to be imported at 200 dpi you can see this in step 10 of the revised tutorial at: http://www.lucidtronix.com/tutorials/20#tutorial-instructions
    Not every bmp in the library was imported at 200 dpi so if they are not appearing on the OS Park site they should be re-imported at 200 DPI or less (and maybe resized first in photoshop or gimp).
    no it was imported as a LBR from the link posted above.. not sure how to change the dpi.. might be good to try an export it as a bmp then re import with low dpi.. can i do this
    Was the image loaded in with import-bmp?
    By default, it renders the logo with 10,000 DPI pixels.  When the website renders it at 300DPI, it just doesn't appear.
    The silkscreen printer is 200DPI, so for best results, re-run import-bmp at 200DPI.
