EAGLE User Support (English) Noob question: How to move a part back off the board
  • Views 464 views
electrooptical
electrooptical over 13 years ago
Hi, all,
Just a quick one.  When first starting to lay out a board, all the parts are positioned in an off-board staging area at the left of the screen.  In laying out a fairly tight board of near the maximum dimensions for Standard Edition, occasionally I make a mistake in placing some group of components, and need to move it to another place.
The natural way to do that would be to move the parts back to the staging area, and then move a different clump.  But I can't find a way to do that without either (a) starting over, or (b) deleting the component and putting it back in the schematic.  I can't believe that there isn't a way to do this, but I can't find it.
What's the incantation to take a part off the board and back to the staging area?
Phil Hobbs
    0 autodeskguest over 13 years ago in reply to dukepro
    On 16/03/13 14:58, Chuck Huber wrote:
    staging area?
    Use move.  You can drag the part off the board.  You can also do this
    from the Eagle command line.  Suppose the part you want to move is R1.
         move R1 (-1in 1in)
    which will move the part to Quadrant 2.
    That won't work with the free or standard editions. The board area limit
    prevents any parts being placed to the left or below the origin, which
    can cause confusion since that's where they are initially dropped when
    added to the schematic.
  • dukepro
    0 dukepro over 13 years ago
    staging area?
        move R1 (-1in 1in)
    You can also group parts with the GROUP command.  You can surround the
    parts to group with a rectangle by dragging from one point on the board
    to another, or select them with a polygon using multiple clicks around
    the components to group, double-clicking to close the polygon.  The use
    MOVE with a Ctrl-click.
    HTH,
        - Chuck
    The mirror command will take care of that.
