EAGLE User Support (English) how to change the thermal isolation
  • Subscribers 180 subscribers
  • Views 864 views
Hello,all
        I have one problem about copper,I don't need the thermal isolation when it is one signal,if you couldn't understand what I mean ,the picture is shown down.
I don't want this style.
I don't want the 4 black blocks,just fill with copper. Can any body  deal with it ?
  • bmoe
    0 bmoe over 12 years ago
    If you look at the properties for the polygon fill and uncheck the "Thermals" option, that will remove all thermal connections for thet polygon.
    There is also an thermals option in the component symbols editor, if you look at the properties for pads.
    /M
    0 Former Member over 12 years ago in reply to bmoe
    wo,I have tried,it is effective.Thank you.it is easy to use "uncheck the Thermals option" when polygon.
