EAGLE User Support (English) ULP question. Get date to automagically show in BOM filename.
  • Subscribers 189 subscribers
  • Views 526 views
bmoe
bmoe over 13 years ago
Hi.
I have usa a modified version of the default bom.ulp wich I have changed a bit to fit my needs, but there is one small thing thet irritates me. I cant get the date to automagically be filled in, in the file save dialog.
Originally the filename comes up like this "schname.csv" and I would like to get "schname YYMMDD.csv" with the day automagically filled in.
Ive tryed alot with the t2string() but as soon as I try to use it in the filename the filename field will be blank instead.
Anyone have a clue?
This is how the save function looks like today.
void SaveList (void)
  string FileName;
  string FileExt;
  switch (OutputFormat)
    case ofText: FileExt = ".txt"; break;
    case ofHTML: FileExt = ".html"; break;
    case ofCSV:  FileExt = ".csv"; break;
  schematic(SCH) FileName = filesetext (SCH.name, FileExt);
  FileName = dlgFileSave (tr ("Save Bill Of Material"), FileName);
  if (FileName)
    string a [];
    if (!fileglob (a, FileName) || dlgMessageBox (tr ("File '") + FileName +
        tr ("' exists\n\nOverwrite?"), tr("+&Yes"), tr("-&No")) == 0)
      output (FileName, "wt")
        printf ("%s", MakeList ()); // using "%s" to avoid problems if list contains any '%'
  • bmoe
    0 bmoe over 13 years ago in reply to dukepro
    Thank you very much. That made my day.
    I started this as a no question thread and then edited it to a question, and now it seems that I cant make it anwerd. I cant find where to do it anyway.
  • dukepro
    0 dukepro over 13 years ago
    On 03/18/2013 05:00 AM, Matias Sjögren wrote:
    Hi.
    dialog.
    Anyone have a clue?
      string FileName;
      string FileExt;
      //schematic(SCH) FileName = filesetext (SCH.name, FileExt);
        int now = time();
        schematic(SCH) sprintf(FileName, "%s %s%s",
            filesetext(SCH.name, ""),    // Get the file name w/o extention
            t2string(now, "yyMMdd"),     // Produce a formatted string
            FileExt                      // Append the extension of choice.
    See section titled "Time Conversions" starting at the bottom of page 103
    in ulp640_en.pdf
      if (FileName)
        string a [];
    FileName +
    http://www.element14.com/community/message/72123#72123
