EAGLE User Support (English) Unexpected Polygon Pour
  • Views 620 views
  • cutout
  • pcb
  • pour
  • polygon
Bertl
Bertl over 13 years ago
According to the documentation, overlapping polygon pours and cutouts should work with recent eagle versions.
The setup is simple, ground on the outside, supply on the inside, and some empty space inbetween.
Nevertheless, I'm unable to get this to work properly and no configuration I tried (ranks, cutout, signal names, ...) gives the desired result.
The questions arising from the attached files are:
- How do I make the pour filling up the space between the power planes disappear?
- Why is the space filled regardless of the 'Orphans' setting?
- Why doesn't the 'cutout' pour have a 'Rank'?
Many thanks in advance,
Herbert
polygon.zip
    0 autodeskguest over 13 years ago in reply to Bertl
    Herbert Poetzl wrote:
    The attached image is indeed what I'm after, but changing the middle
    polygon to cutout only looks like it would work because of the lazy
    updates to polygon pours.
    The moment you press the 'Ratsnest' button, the inner polygon becomes
    unfilled as well, probably because the connection to the part is
    inside the cutout region, which doesn't have a rank.
    But thanks for the efford,
    Herbert
    http://www.element14.com/community/message/72737#72737
    Sorry, I was a bit quick to respond.
    Reading the HELP reveals that  the cut pour  works like a 'cooker cutter'
    and takes out the area of all signal layer polygons that it covers.
    Warren
    news.cadsoft.de
  • Bertl
    0 Bertl over 13 years ago in reply to autodeskguest
    The attached image is indeed what I'm after, but changing the middle polygon to cutout only looks like it would work because of the lazy updates to polygon pours.
    The moment you press the 'Ratsnest' button, the inner polygon becomes unfilled as well, probably because the connection to the part is inside the cutout region, which doesn't have a rank.
    Herbert
    0 autodeskguest over 13 years ago in reply to autodeskguest
    Warren Brayshaw wrote:
    Is the attached image what you are after?
    I simply changed the pour of the cutout polygon to 'cutout'.
    v6.3.3 on Windows
    You wont get the attachement at Element14, they havn't worked out how
    to pick it up from the Newsgroup  news.cadsoft.de You best pick it up
    at EagleCentral http://www.eaglecentral.ca/forums/
    HTH
    Warren
    Web access to CadSoft support forums at www.eaglecentral.ca.  Where
    the CadSoft EAGLE community meets.
    I see that images do get to Element14 now. That would have been a good thing
    to announce in eagle.announce.eng
    Warren
    news.cadsoft.de
    v6.3.3 on Windows
    You wont get the attachement at Element14, they havn't worked out how to
    pick it up from the Newsgroup  news.cadsoft.de You best pick it up at
    HTH
    Warren
