EAGLE User Support (English) impedance between 2 pads
  • Subscribers 189 subscribers
  • Views 386 views
roellenssen
roellenssen over 13 years ago
I have 2 connectors on my board.
Each connector has a power pin wich is connected on the board with a large polygon plane.
Is to possible to calculate (with an ULP, or something else) the impedance between the pads of both connectors?
Thanks in advance.
Roel Lenssen
  • roellenssen
    0 roellenssen over 13 years ago in reply to e14 Contributor
    Of couse I need all the items you numbered.
    I'm just interested in the DC impedance of the plane (to check the max current from connector to connector).
    I was just hoping if there's some tool wich does the calcution within Eagle.
    It is possible, of course, but one needs:
    (1)     the dimensions of the pads
    (2)     their geometrical relationship to one another
    (3)     the physical/chemical characteristics of the substrate (material & thickness)
    (4)     the existence, or not, of conductors beneath the pads; are they grounded?
    (5)     the frequency range in question (impedance is proportional to applied frequency).
    (6)     a bit of integral calculus to establish the E-flux in the volume of space around the pads.
    I'll bet someone can specify a suitable program to run on a PC and give an answer in a second or two!
