EAGLE User Support (English) How to Polygon fill with isolate 0?
  • Views 635 views
Hi There,
I'm trying to develop a ULP that detects the outline of the traces on a layer and converts them into gcode.
I know this has been done before, but I'm trying to understand how it works.
Anyway, what I've found is doing a ground plane fill usually ends up making a polygon that has a contour with the information that I want.
What i've tried is the following: (typing in the commands manually)
polygon _TEST_ 0.0001 (0 0) (0 400) (1000 400) (1000 0) (0 0)
ratsnest
This fills the empty space around the traces with a ground plane. But the ground plane is too far from the edge of my traces.
ideally, I would have the polygon go right up to the edge of my traces.
so I tried this:
change isolate 0.0001
ratsnest
But I got the same result as the first commands.
I've also tried using 0 as the isolate value. But it always seems to keep it's distance and never approaches the traces closer than 0.4mm ish?
What have I done wrong?
Josh
    After further searching, I've found what I'm looking for
    Because I want the outline of the traces, it turns out there is a special polygon name to use that means DRC rules are ignored.
    The relevant details are here:
    http://web.mit.edu/xavid/arch/i386_rhel4/help/124.htm
    Importantly:
    change rank 6
    and use polygon name _OUTLINES_
    so the following works:
    change rank 6
    polygon _OUTLINES_ 0.0001 (0 0) (0 400) (1000 400) (1000 0) (0 0)
    ratsnest
    0 autodeskguest over 13 years ago
    ish?
    There also are minimum distances set up in the net classes and the
    general design rules (DRC).
    The largest of all applies.
    Tilmann
