EAGLE User Support (English) shrinking the board size in Eagel
  • Subscribers 187 subscribers
  • Views 366 views
  • board
  • eagle
  • size
  • shrink
  • coil
Hello. So i designed this ring-shape board with chips, spiral coils and two capacitors on it now i want to shrink the coil size, say from 19mm (outer diameter) by 12mm (inner diam.) to 15 by 8mm. Im just wondering if this is something that is possible to be done in Eagle. So far,  i havent found anything.... maybe in other versions there are.
Here is the screenshot:
Id appreciate any feedback or comments.
Lala~
    0 autodeskguest over 13 years ago
    There is a ULP sold by Falk Stricker (mailto:Falk.Stricker@gmx.de)
    You can see how it looks (demo version, look see )by downloading
    Eagle_PCB_Power_Tools from
    http://www.cadsoftusa.com/downloads/tools-and-converters
    It contains scale.ulp which looks like it can scale a whole board. Note
    that from the scaled images in the demo ULP the board and elements have
    been scaled which is not what you want. You want every thing scaled but not
    the elements/packages. Check with Falk that this is what happens.
    HTH
    Warren
