EAGLE User Support (English) Eagle 6.4 Linux screen issues
  • Replies 10 replies
  • Views 1468 views
  • bug
  • screen
  • linux
I have just downloaded eagle 6.4 for my Ubuntu Quantal 12.10 64-bit.
Upon running it, the main screen (where I have my schematic or my board layout) gets impossible to read if any scrolling/zooming is done.
I have tried what is suggested on the FAQ, but to no success (export XLIB_SKIP_ARGB_VISUALS=1).
I am using AMD 3D drivers 13.1. KDE seems not to be the issue (have tested with other window managers).
This is what I see:
And this is what I wanted to be seeing:
Is anyone aware of a fix for that?
Thanks!
    Hi guys,
    i got some new infos... i managed to get it work... on certain sizes it's ok ! !
    you """just""" have to size the window...
    what you have to do :
    - do not have it on full screen
    - size the vertical window size for almost the 9/10 of the screen
    - then size the horizontal size, slowly.
    - on one size you'll see the correct image, test by zomming in and out... at first glance there is only one combinaison of width/height that work
    i managed to get the two windows ok with that,
    i hope cadsoft is working on that issue !
    Hi guys,
    do you have others methods to solve ?
    It seems to work. Not the best option, but I guess it's all we have for now.
    Thanks!
    I have the same problem running Linux Fedora 18 (did it in 17 also).  Using KDE, if I go to System Settings, Desktop Effects, Advanced and change Compositing type from OpenGL to XRender, Eagle works fine.
    It's a pain cause I switch back to OpenGL before using other things like Google Earth, Blender, etc..
    I've tinkered around quite a bit and have found no other fix/workaround.
    Dave
    0 autodeskguest over 13 years ago in reply to e14 Contributor
    On 04/09/2013 08:19 PM, Riccardo Delai wrote:
    A note here: Downloading a PREVIOUS (5.x) version of Eagle from the
    repository works ok.
    Unfortunatelly, I need 6.x.
    Try turning off Display Compositing. That fixes the problem for me, but
    may annoy other applications you're using.
    -Reece
    On 04/07/2013 09:47 PM, Riccardo Delai wrote:
    I've been using Eagle 6.2.0 for quite a while on a 64-bit installations
    of Ubuntu Maverick 10.10 without any problems. A couple of months ago I
    upgraded to Linux Mint Nadia XFCE (it's a respin of Ubuntu Quantal
    12.10). I DON'T have the Unity interface installed (if I wanted a crappy
    Mac interface, I'd have bought a crappy Mac).
    Since the upgrade I've been working mostly with the board editor and
    haven't seen any real problems with rendering, but this morning I used
    the "show @" command to find something on a schematic and noticed it
    (see attached PNG). I have a full-window capture, if it's more useful to
    tech support, but it won't fit through the NNTP server.
    If it proves to be repeatable I'll see if I can find a workaround.
    -Reece
    This is what I see:
    Thanks!
    http://www.element14.com/community/message/73546#73546
    One thing to look at when having text issues while scrolling/zooming is your
    system fonts. With the schematic open, try using vector fonts (menu Options-
    User Interface). If that helps, you possibly have a font issue. I'm a Gentoo
    user, so I don't know the incantations for Ubuntu. However, one thing I do
    on my system that resolves a lot of Eagle font issues is to turn off the
    system bitmap fonts. That's 'eselect fontconfig 70-no-bitmaps.conf' on
    Gentoo. Ubuntu should have some sort of similar functionality.
    A note here: Downloading a PREVIOUS (5.x) version of Eagle from the repository works ok.
    Yes they are working fine, also on 3D applications.
    I have actually updated them in the process of trying to get this to work, but no luck.
    Hmm never had this problem before myself... you're sure all the drivers are installed right? I run Ubuntu 12.10 on my macbook (32bit), and once I got all driver issues sorted out it worked fine.
