EAGLE User Support (English) EAGLE 6 Dimension command
  • Views 403 views
Seems that the Dimension command has limitations in that it won't support grouped items.
I wish to change, as a group, the units from mils/mm and Units Show ON or OFF, offset extension parameters, etc.
Can this be done as a group?  In a complex design, manual individual changes are painful!
Else, CADSOFT, could it be implimented please in a V6 release update?  Would be nice if 2 dimension unit types could be shown simultaneously.
  • bmoe
    0 bmoe over 13 years ago
    Hi.
    If you start with grouping all of your dimensions you want to change, then in the Command button toolbar you can change the Dtype and Dunit parameters. When you are done you just Ctrl + Right click anywhere in the working area to apply the changes to everything in the group.
    /Matias
