EAGLE User Support (English) Adding components after the board has been laid out??
  • Subscribers 189 subscribers
  • Views 395 views
packhorse
packhorse over 13 years ago
I draw up a schematic then generate a boar and lay that out how I want it.
I then find out I left a component off the schematic and so add it but it does not get added to the board.
How do I "refresh " the board based on the updated schematic?
Greg
  • packhorse
    0 packhorse over 13 years ago in reply to dukepro
    Thanks. That helps!
  • dukepro
    0 dukepro over 13 years ago
    it.
    When you add the new component, make sure both the schematic and the
    board layout windows are both open.
    The easy way is to delete the component from the schematic, then run an
    ERC to make sure the board and schematic are consistent - they match
    each other.  Again, make sure both windows are open when you do the ERC.
    Once the board and schematic are consistent, then you can add the new
    component to the schematic and make all the net connections as desired.
    Then, flip over to the board layout window to place the package and
    route the air wires.
    HTH
        - Chuck
