EAGLE User Support (English) How to make components look as whole instead of consisting of multiple elements?
  • Subscribers 187 subscribers
  • Views 339 views
Here is what I mean. For example I select CMOS 4011 and I am offered to place 4 seperate nand elements. Is there a way to show the whole "body"?
    0 autodeskguest over 13 years ago
    Only if you draw a new symbol. The 4011 is defined as a device containing
    two hidden power pins and four gates which each use the same symbol. You
    want a new symbol showing all pins and the gates inside, I presume, a
    bit like the footprint. The new symbol needs a new device, which will
    have the same package(s), so you'll need to learn to create devices and
    symbols, and connect the pins on existing footprints. In short, you must
    know almost everything about how to create library parts. There are good
    tutorials in various places, luckily.
    Clifford Heath.
