how can I forbid the autorouter to use the pins of certain components (parts) as a via? Because some components I can't solder from the top, only from the bottom and I can't make the vias conductive at home.
Thank you for your help.
Oh that helps, thank you.
Patrik Túri <noreply-181745@element14.com> wrote:
As workaround, put some pattern on xrestrinct around the pad.
Uwe Bonnes bon@elektron.ikp.physik.tu-darmstadt.de
Institut fuer Kernphysik Schlossgartenstrasse 9 64289 Darmstadt
Tel. 06151 162516 -
Fax. 06151 164321 -
