EAGLE User Support (English) ruler command in eagle?
  • Subscribers 177 subscribers
  • Views 2037 views
Is there some way to tell the distance between two points in the Eagle pcb
layout?  Right now I'm just watching the cursor and writing down the XY
coordinates and calculating it the hard way.
I searched for "ruler" and "measure" but can't find anything in the
manual...
Thanks in advance.
Henry
    manual...
    Thanks in advance.
    Henry
    Use the mark command.  Help says: "The MARK command allows you to define
    a point on the drawing area and display the coordinates of the mouse
    cursor relative to that point at the upper left corner of the screen
    (with a leading 'R' character). This command is useful especially when
    board dimensions or cutouts are to be defined. Entering MARK; turns the
    mark on or off."
    -Dave Pollum
    Henry,
    Check out the EAGLE Power Tools by Falk Strciker (see download area) - there is
    a measurement tool there.
    Regards, Philip.
    Puresoft - Software Specialists
    www.puresoft.com
    T 0845 226 90 50
    F 0845 226 90 20
