EAGLE User Support (English) Can't find a 2 pin non-smd push/tact button in Eagle 5.2.0 Light
  • Views 2355 views
I am doing a small project using Eagle, but I can't find a non-smd 2 pin
push-button in any of the libraries. I have tried to search for
"button"/"switch"/"tact"/"push" - no success. Can you tell me what to use
because I want to avoid creating my own library.
Thank you,
Vlad.
PS: the size of the this push button is about 6x6mm. I don't have any
datasheet for it.
    Go here for a switch like you described:
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=SW796-ND
    I don't understand your reluctance to create a library part, especially
    since your part only requires two vias for the through-hole pins.  I
    recommend you research parts and availability before you design a board.
    DigiKey has links to spec sheets for what they sell.  Learning how to make
    custom library is well worth the time it takes.  Your switch would make an
    excellent starting point.
    "Vlad" <vlad@none.com> wrote in message
    news:gdh2tm$c1u$1@cheetah.cadsoft.de...
    Thank you,
    Vlad.
    datasheet for it.
