EAGLE User Support (English) Disappearing Library
  • Subscribers 178 subscribers
  • Views 546 views
  • library
I had a library of parts that I made for myself. It was named !My_Stuff.lbr and everything was working fine; I had used the parts in my designs and was able to make working boards from them. I even had backup copies of the library.
Suddenly the library has disappeared! I can't fine it in EAGLE and I can't find it using windows explorer. Can anyone tell me what might have happened to my file?
TIA
    I am replying to my  own posting,....
    OK, so I have lost my furschlugginer library >:(
    I still have the parts in my drawings. How do I reconstruct the .sym and .pkg parts in a new (hopefully more robust) library using the components from the schematic and layout files? I am using Version 6.4 on Windows 7.
    0 autodeskguest over 12 years ago in reply to Former Member
    Op Mon, 20 May 2013 17:05:57 +0200 schreef Paul Horst
    <noreply-105171@element14.com>:
    7.
    Just a thought: have you tried looking in:
    C:\Users\'username'\AppData\Local\VirtualStore\Program Files
    (x86)\EAGLE-x.xx.x
    for your library?
    Windows 'User Account Control Data Redirection' has already suprised more
    people on this forum. Worth a look. By default the 'Appdata' folder is
    hidden, so you may have to adjust your settings to see it.
    If your lib IS there I recommend NOT placing your lib, ulp, etc folders in
    a 'Program files' subdir. Place them in your document folder (where you
    have access rights).
    If your lib is gone, use one of the export ulp's. On 5.x there's
    'exp-project-lbr.ulp'; it probably exists in 6.x, but I don't know for
    sure.
    Richard
    0 Former Member over 12 years ago in reply to autodeskguest
    Ok Richard, I found the path specified up to the "Local" folder but there is not "VirtualStore" folder. Are you sure about that path?
    0 Former Member over 12 years ago in reply to Former Member
    I found that .ulp in the EAGLE 6.3 installation and tried it with 6.4 and it worked.
    Thanks for the info!
    -Paul
    Op Mon, 20 May 2013 20:54:36 +0200 schreef Paul Horst
    Yes, I'm sure about the path. See for an explanation ie.:
    https://decibel.ni.com/content/groups/windows-7/blog/2009/10/02/uac-virtualization-and-how-it-affects-your-installers
    Anyway, if the folder isn't there, then your lib certainly isn't,
    unfortunately...
    If the 'export' ulp worked, than at least you can rebuild some of the lost
    lib.
    Succes.
    Richard
