EAGLE User Support (English) Best way to save project before routing
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 825 views
This is my first Eagle project, I am new to pcb design.
Can someone tell me what the best way is to save a project before routing?
I have completed my schematic and placed all my components on my board. This was very time consuming
I want to try routing a few different ways, including manual and auto, and want to be able to go back in case I mess something up.
I will try a 2 layer configuration first, but might need to use 4 layers.
I know that cntr Z goes back one step, but not sure how many steps I can go back with it.
I had an issue before were I lost my back/forward annotation and had to start over again with the layout. Don't want this to happen again.
Thank yo for your help.
Robert
    0 autodeskguest over 13 years ago in reply to e14 Contributor
    Robert Muertter wrote:
    Thanks for all your help!
    I ended up using the copy function, as there is no "save as", and copied
    it in another folder and renamed it.
    I also copied it to my Dropbox. Sofar my design is going well...
    I believe Eagle also saves a buch of previous versions, they all show up
    in the copied folder.
    You can set the amount and frequency of auto-backups in Eagle via
    Options -> Backup, in the Control Panel. In version 4 the max number of
    stored files is 9 and the max auto-save interval length is 60 minutes. I
    keep both set to those limits so if I ever did something really stupid
    it would cover me for a workday.
    Regards, Joerg
    I ended up using the copy function, as there is no "save as", and copied it in another folder and renamed it.
    I believe Eagle also saves a buch of previous versions, they all show up in the copied folder.
    Thanks alot for the help!
    Robert
  • fritzz
    0 fritzz over 13 years ago
    why not just do a  "save as"?
    0 autodeskguest over 13 years ago in reply to autodeskguest
    James Morrison wrote:
    reece wrote on Thu, 23 May 2013 19:50
    On 05/21/2013 09:20 AM, Robert Muertter wrote:
    routing?
    I'm a software engineer by profession, and I've learned the importance
    of proper use of a code management utility. I commit my changes each
    time I reach a point I want to be able to return to, and document what
    changes I've made in each commit. This is especially useful when
    working
    with schematics and board layouts as a textual diff often isn't that
    illuminating.
    It may sound like a pain, but it's not. Subversion is trivially easy
    to
    use and has good support on almost every platform (Linux, Windows,
    Mac,
    Solaris, etc.).
    I agree subversion (or other revision control is a good idea).  However, if
    you're at a point you don't want to commit then just copy the whole project
    folder.  If you ever need it, just rename directories to get back to where
    you where.
    And set up that stack of backup directories on another drive across a
    LAN or at least a USB stick. I still remember a guy at my first job. The
    hard disk made an odd noise, then ... rat-tat-tat ... KERKLUNK ...
    followed by a scream from the engineer.
    Regards, Joerg
    routing?
    working
    illuminating.
    to
    Mac,
    Solaris, etc.).
    you where.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    routing?
    changes I've made in each commit. This is especially useful when working
    illuminating.
    It may sound like a pain, but it's not. Subversion is trivially easy to
    use and has good support on almost every platform (Linux, Windows, Mac,
    Solaris, etc.).
    routing?
    layers.
    go back with it.
    Hi Robert, I can't help much with this because I don't use Eagle 6 and
    don't do layout myself. But until someone comes online with an expert
    answer maybe do this:
    Last Wednesday I had a similar pickle. I used a software that was new
    for me, for the first time at a very important event (clinical trial).
    In other words the proverbial white-knuckle ride. What I did to make
    absolutely sure that the software (or I ...) wouldn't accidentally
    trample a saved but non-repeatable recording I regularly exported it all
    to extra directories at regular intervals. Each such file dump got a new
    directory. I even used a USB stick, in case the hard drive decided to
    croak that afternoon. Back home I verified that the originals were ok,
    backed them up and then erased all the extra directories.
    Regards, Joerg
