EAGLE User Support (English) Low plating index
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 2237 views
  • eagle
  • copper
  • problems
Low plating index
Ok so I just got a issue back from my board house, I combined 5 pcbs in one panel.
You can see the info in the uploaded picture. The plating index is low and it need to bost it up. I understand I need to make the copper distribtion move even (even though im not sure what 'even is') Am I right in saying one way is to add copper traces which dont do anything where I can on the board? Or I read somewhere that you can fill another layer with copper or something like that. Only thing is im working with eagle light so I only have two traces which Ive used both as much as each other on all the boards.
Also where it says it may get brunted for instance where the redish color is on that 10 pin header. That is because I had to ground 4 of the pins, I dont think there is anyway round this as I need to keep it like that. I also attached a zoomed in pic.
Could anyone take a look and tell me what is acctually bad and what needs to be changed. And how I need to go about doing that on eagle.
Thanks!
    0 autodeskguest over 13 years ago in reply to dukepro
    On 05/29/2013 07:45 AM, Chuck Huber wrote:
    Matt, et al.,
    I think I just found a decent explanation of plating index.
    Check out this article at eurocircuits
    <http://www.eurocircuits.com/index.php/eurocircuits-printed-circuits-blog/plating-simulation-a-new-tool-for-pcb-designers>.
    Rather than starting with a copper laminate panel and removing copper in
    unwanted areas, they're starting with a bare fiberglass (for FR4) panel and
    using galvanic copper deposition to add copper in wanted areas.
    Close.  The panel starts out with a thin copper layer, much thinner than
    the final copper thickness.  The panel is then given a negative mask,
    leaving the desired traces exposed, and the exposed areas plated up to
    the desired thickness.  Then the negative mask is removed, a positive
    mask applied, and the undesired copper is etched away.  The advantage is
    that only the thin initial layer needs to be removed by etching.
    Bob Nichols         AT comcast.net I am "RNichols42"
  • dukepro
    0 dukepro over 13 years ago in reply to dukepro
    Matt, et al.,
    and using galvanic copper deposition to add copper in wanted areas.
    The problem focuses on the holes.  Overplating can result in the holes
    closing up to a smaller than desired diameter.  Underplating risks thin
    walls in the holes.
    A low plating index means that your design has /more/ copper than the
    average of the board and risk thin traces and hole walls.  To correct
    this, you need to remove copper from that area, or increase the average
    of the board by adding copper elsewhere.
    A high plating index means that you have /less/ copper than the board's
    average.  In these areas you need to add copper.
    In your last post, adding a hatched polygon to the low plating index
    area is exactly opposite what you need to do.
    More specific to Matt's original problem, one solution may be to widen
    your traces.  Even though they're carrying signal level currents, they
    can be wider.  A wider trace can withstand more flexing of the board
    when it's exposed to mechanical shock and vibration.
    Another solution would be to change the hatched polygon to encompass the
    entire board.  This would provide a more even distribution of copper
    throughout the entire board.  If you name the polygon "GND", it will
    connect to all the other GND signals.
    HTH,
        - Chuck
    On 05/29/2013 08:04 AM, Chuck Huber wrote:
    On 05/28/2013 05:00 PM, Matt Porta wrote:
    So bascily this pcb here is causing me greif because of the amount on un
    used space on the far right. So bascily I have put in a polygon hatched
    in a big open space. I dont want to to do anything just to even out the
    copper.
    Would what ive done here be suitable? Im just not sure how to add it to
    this pcb. I guess im pretty hestitant to add random traces via's etc as
    Im not sure where would be best and dont want to interfere with
    anything.
    I've never heard of a plating index, either.  It may have something to
    do with the amount of time the board stays in the etching solution.
    Areas with little copper will take more time to etch that areas with a
    lot of copper?  It doesn't make sense, though, assuming that the entire
    board is exposed to a homogeneous etching solution.  Frothing will not
    only reduce the etching time, but it will also yield a more even etch
    with less undercutting.
    I'd like to understand exactly what a plating index is, how it plays in
    the fabrication process, and why it's a design concern.
    When you find out, I'd appreciate a post regarding this.
        - Chuck
    8867.att1.html.zip
  • dukepro
    0 dukepro over 13 years ago in reply to e14 Contributor
    copper.
    anything.
        - Chuck
    0 e14 Contributor over 13 years ago in reply to autodeskguest
    Thanks alot Tim this helped me alot. I do understand the cocept of what your saying, but trying to use in within a design ive allready layed down seems still a bit confusing.
    So bascily this pcb here is causing me greif because of the amount on un used space on the far right. So bascily I have put in a polygon hatched in a big open space. I dont want to to do anything just to even out the copper.
    Would what ive done here be suitable? Im just not sure how to add it to this pcb. I guess im pretty hestitant to add random traces via's etc as Im not sure where would be best and dont want to interfere with anything.
    I attached the .brd file if you want to take a futher look and see what would be best!
    Thanks again Tim
    http://www.sendspace.com/file/pq5khc
    Heres the .brd Its on sendspace because I couldnt attached directly in a reply!
    0 autodeskguest over 13 years ago in reply to e14 Contributor
    On Fri, 24 May 2013 12:13:13 +0000, Matt Porta wrote:
    Yeah, im just waiting for a reply back from them!
    I think its pretty much about a even copper distrubtion. They said they
    will fill the areas between boards to even it out. But could you shed
    some light about how you would go about getting a even copper on a
    single pcb after the traces have been put down image
    After I autoroute a board, I define a pair of filled polygons on the top
    and bottom, connected to ground.  I use a grid fill.  This will do a
    pretty good job of filling up the board.
    Then, if I'm even the least bit concerned about signal integrity, I
    dribble ground-connected vias around the board to connect the top and
    bottom fills (and if I'm feeling ambitious, to get more fill in empty
    areas).
    If you're autorouting, you want to do this AFTER you route -- otherwise
    the autorouter will connect ground to the polygons, and slice up the
    polygons.  If you've put down the polygons and you want to make changes
    that include autorouting, the easiest thing I've found to do is to rename
    the nets (to Bob, or Ralph -- anything that's not already a net name),
    autoroute, then rename them to ground again.  If you did the via drop
    thing then when you rip up everything to reroute you'll blow away the vias
    and you'll have to redo.
    My liberal friends think I'm a conservative kook.
    My conservative friends think I'm a liberal kook.
    Why am I not happy that they have found common ground?
    Tim Wescott, Communications, Control, Circuits & Software
    http://www.wescottdesign.com
    The PCB house I use told me that they need a "similar" proportion of
    copper vs. gap on all layers, but they were OK with a corner of the
    board being very sparse on all layers when the rest of the board is
    extensively flood-filled. It sounds like YMMV, though.
    Rob
    I think its pretty much about a even copper distrubtion. They said they will fill the areas between boards to even it out. But could you shed some light about how you would go about getting a even copper on a single pcb after the traces have been put down image
    one panel.
    Thanks!
    http://www.element14.com/community/message/77552#77552
    Screen shot 2013-05-23 at 20.56.10.png Screen shot 2013-05-23 at
    I dunno what this "plating index" stuff is.  You can always ask -- your
    PCB vendor probably already knows you're a newbie, so asking naive but
    intelligent questions will only raise their impression of you.
    At a guess if you fill the areas between boards with a grid of traces
    then your copper would be more even.  That may make them happy.
