EAGLE User Support (English) SMD Pad and tstop layer
  • Views 1752 views
I am in the library editor creating a new package (footprint).  I am
using the SMD Pad tool and have no problem placing pads.  What I do have
a problem with is that the tstop layer is larger than than the pad.  Why
is this?  How can I make it the same size as the pad?  I am trying to
manually edit the layer and rectangle but it doesn't seem to be working.
Thank you,
Tim
    It is best to not top post and cut unused context.
    Timothy D. Swieter wrote:
    Thank you for the response and your experience Paul.
    I have my library footprint open, but I don't see how to modify the DRC
    setting you are referencing.  If I go to 'Option', then 'Set...' a
    dialog opens that has a title of 'Settings' and there is a 'DRC' tab,
    but the only thing on this tab is 'Fill style of error polygons' and
    With the board edit window open the DRC and look at the mask tab.
    nothing else.  I would like to turn off the auto tstop or at least be
    able to adjust how much larger the tstop is.  Can you help me further
    and let me know where I should be looking to adjust the setting?
    With the lib edit window use change stop (on/off) to change the stop
    mask. When off you will have to add to the top and bottom stop layer a
    polygon, rectangle or wires to make the shape you need.
    On the last couple boards I made I didn't check the tstop, then when I
    got the board back one or two pads on each SMT I used would be larger.
    The larger pad as the ground pad because I did a ground fill without
    thermals and with the larger tstop this made the pad larger.  Hand
    soldering was more difficult on my fine pitch SMT because of this and I
    would like to fix it.
    I use http://www.freedfm.com and a Gerber viewer to verify the artwork.
    Paul R.
    have a problem with is that the tstop layer is larger than than the
    pad.  Why is this?  How can I make it the same size as the pad?  I am
    trying to manually edit the layer and rectangle but it doesn't seem
    to be working.
    Thank you,
    Tim
    It is modified by DRC settings. You can turn off the auto tstop and
    draw your own. Note PCB houses seem to want the stop bigger then the
    pad to allow for alignment errors and will fix up your art work or say
    it is a problem if it is too tight.
    What I have seen under microscopic inspection is solder and flux will
    migrate under the mask and cleaning the flux becomes difficult.
    Paul R.
    Thank you,
    Tim
    It is modified by DRC settings. You can turn off the auto tstop and draw
    your own. Note PCB houses seem to want the stop bigger then the pad to
    allow for alignment errors and will fix up your art work or say it is a
    Paul R.
