EAGLE User Support (English) how to present a solenoid in the eagle schematic
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 178 subscribers
  • Views 2366 views
  • eagle
  • eagle_library
  • solenoid
i am trying to present a solenoid on the schematic but could not find a component from any of the libraries i have, any one know where i can find one? it does not have to match the specs as long i get the symbol as i can use jumper wires to get it in the board
regards
    0 autodeskguest over 12 years ago
    Op Sat, 22 Jun 2013 10:02:49 +0200 schreef mohammed alkindy
    <noreply-190527@element14.com>:
    You will probably have to make a choice here: If you don't want the
    solenoid to be on the board, you can't really use a regular Eagle symbol
    for it, because the package will appear on the board.
    Probably the easiest thing to do here is just use wirepads to connect the
    solenoid to (from wirepad.lbr, or make your own), and in the schematic
    pick a non essential layer and draw the symbol for yourself (with wires,
    circles, etc.) to represent it's function.
    This item (off-board components) comes up regularly, but so far I haven't
    seen a good solution, and probably won't until Cadsoft puts it on it's
    to-do list.
    The second best solution so far is a ulp from Andreas Weidner (I believe,
    do a search), where you can take a regular eagle device, and the ULP will
    put the symbol on a non essential layer and remove the package from the
    board. So if you find a device in an Eagle library and want to put it
    off-board, this will help.
    Richard
    0 Former Member over 12 years ago in reply to autodeskguest
    thank you Richard, i will try the first proposal, however i will need to see how to find a non essential layer since i am using the 6.4.0 Light Edition. for the second option i need to do some researchas iam new to eagle package and do not know much about ULP!!!!????
    regards
    mohammed alkindy
    0 autodeskguest over 12 years ago in reply to Former Member
    Op Sat, 22 Jun 2013 13:49:25 +0200 schreef mohammed alkindy
    Hi Mohammed,
    You can use layer '97 - info' or '98 - guide' in the schematic editor, or
    you can define your own layer. See 'help layer' for that.
    If everything goes well, you'll find the ULP attached. (explode.ulp). It
    was indeed from Andreas Weidner. If there is no attachment (I use the
    newsgroup, not Element14), you can download it from www.cadsoftusa.com,
    download section. You have to 'group' the elements you want to turn to
    graphics. just experiment with a test schematic to see how it works.
    Richard
    explode.ulp.zip
    0 autodeskguest over 12 years ago in reply to autodeskguest
    Am 22.06.2013 14:56, schrieb Richard Herman:
    Hi Mohammed,
    or you can define your own layer. See 'help layer' for that.
    Richard
    If you want to use your own layers for something go over 100!
    Joern Paschedag
    Op Sat, 22 Jun 2013 18:46:23 +0200 schreef Joern Paschedag
    <jpaschedag@t-online.de>:
    True. Although it is mentioned in the 'help layer', who reads that? ...
    Richard
    If you expect to need the solenoid in the same or a very similar fashion
    on another design in the future I suggest to make a library model for
    it. Seems like a lot of work right now but you'll learn from that
    exercise and you'll be thankful to yourself when the time comes where
    you need another solenoid.
    If it's a one-time use, I sometimes draw it into the schematic with
    wires, arcs, radiuses and so on. In that case I switch to the symbol
    layer so that the netlister won't think it's unconnected nets.
    Regards, Joerg
    thank you all for all those suggestions, for now i will be fine with the wire-pad solution, but sure it is will be a learning experiance for me to learn for a purpose
    regards
    mohammed alkindy
