EAGLE User Support (English) drc clearance errors
  • Subscribers 187 subscribers
  • Views 432 views
  • drc
  • error
  • clearance
Noobie to Eagle trying to layout a simple 12V to 5V board for use in a car with spiky power.
I have laid out the circuit ( see links) and imported the DRU from a board manufacturer.
I have checked the Net Classes definitions.
I still get Clearance errors everywhere, even between pads on same footprint.
I have set the grid down to 6mil and looked at the board and the gaps seem to be larger than the spec.
I need help!!!!    Both to fix this problem and to understand what is wrong so I can avoid it in the future.
Thank
Bob Workman
http://members.shaw.ca/bob.workman/power%20supply.brd
http://members.shaw.ca/bob.workman/power%20supply.sch
    0 e14 Contributor over 13 years ago in reply to autodeskguest
    Thanks for the reply
    Once I edited the Net Classes to a compatible value 0.1524mm rather than 6mm things worked well.image
    Onward to the next challengeimage
    0 autodeskguest over 13 years ago in reply to autodeskguest
    Am 01.07.2013 06:39, schrieb Joern Paschedag:
    Am 01.07.2013 03:58, schrieb Bob Workman:
    board manufacturer.
    footprint.
    Thank
    Bob Workman
    http://www.element14.com/community/message/81621#81621
    Your net class is faulty. The width, drill, clearance is given in MIL,
    in the second part of net class width, drill and clearance matrix is
    given in MM image
    Actually I mean the difference between design rules and classes, mm/mil.
    Joern Paschedag
    board manufacturer.
    footprint.
    Thank
    Bob Workman
    given in MM image
    Joern Paschedag
