EAGLE User Support (English) V6 Autoroute Problem
  • Subscribers 178 subscribers
  • Views 350 views
brohogan
brohogan over 12 years ago
Hi, I'm new here.
Since I switched to V6 many of the boards I made with V5.11 will no longer autoroute after they have been ripped up.
On V5.11 they autorouted 100%.
These boards are fairly complex and have a ground plane. There now seems to be a lot of open areas of the ground plane and lots of airwires.
I'm using the Sparkfun DRC and can't see anything that has changed other than the version of Eagle.
I would be surprised if the autorouter has changed that much, and hopefully it's a setting or something.
Any ideas or help is appreciated.
    0 autodeskguest over 12 years ago
    John Giametti wrote:
    Hi, I'm new here.
    airwires.
    Hi  John
    The most likely culprit is the routing grid setting in the autorouter. Make
    it a little finer.
    HTH
    Warren
    news.cadsoft.de
  • brohogan
    0 brohogan over 12 years ago in reply to autodeskguest
    Thanks for your input Warren.
    I did try reducing the routing grid setting from 8mm all the way down to 2mm in steps. (I had time on my hands ;-)
    Still no luck - broken polygrams and air wires where there was none in v5.11.
    I guess they must have changed an algorithm or something. The differance is rather surprising. Too bad, I really like V6.
    I have no experiance in hand routing and the boards are fairly complex or tight. Doing it by hand seems rather daunting.
    Thanks again, though.
    0 autodeskguest over 12 years ago in reply to brohogan
    to 2mm in steps. (I had time on my hands image
    v5.11.
    http://www.element14.com/community/message/78928#78928
    2mm is a large routing grid in many instances. The routing grid you should
    use depends on the scale of your components. The size and pitch of the pins
    in your design will determine your routing grid requirements.  The manual
    does provide assistance here with guidance on choosing a routing grid pitch
    to facilitate autorouting between pins.
    If you have a DIL IC package in your design the pins are 2.54mm apart so if
    you want a trace between the pins a routing grid of 1.27mm would do you
    provided the IC pins are already on a 2.54mm (0.1") grid.
    All the best
    Warren
    news.cadsoft.de
