EAGLE User Support (English) Importing board outlines from AutoCAD
  • Subscribers 177 subscribers
  • Views 568 views
I have several complex board outlines generated in AutoCAD (.dwg files).
They include complex curves which appear difficult to recreate.  Is it
possible to import these board outlines into Eagle Layout.  I can find no
import options of any kind.
Thanks for any guidance,
Ted
    As far as I remember, there are ULPs which allow you to import DXF in
    Eagle. See the download section on the CadSoft site.
    If you have complex outlines, it might be necessary to write them into a
    DXF file and use DWG/DXF version R12. In this version, vomplex entities
    are reduced to facets.
    Best regards,
    Günther
    Perhaps you can export them with AutoCAD to a format for which an import
    converter is available (DXF? Gerber? HPGL?).
    Look into the download section at the CadSoft homepage for import tools.
    They usually create script files that then can be executed from within
    EAGLE.
    Tilmann
