EAGLE User Support (English) Make a hotkey to switch layers & slow follow-me
  • Subscribers 189 subscribers
  • Views 836 views
I am fairly new to Eagle CAD and the forums here.  Probably an easy one.  What is the command to switch layers when manually routing?  I know I can click on the select layer box in the top left, but I would like to map a hotkey.  I figure it is something like "change layer route top" or something.  I tried a few combinations with no luck.
Another thing I noticed, is that the follow-me routing is too slow to even use.  Is it just my machine, or do other people experience this?  I am running windows 8 on a dell latitude e6430.  When I click the "follow-me (from one side)", and start to route, the entire program freezes until I switch back to manual routing and grab a cup of coffee.  It's also a fairly busy design which I am sure is a factor.
Eric
  • gtv31
    0 gtv31 over 8 years ago
    Here you can find an article to the Hotkey solution.
    http://www.blog.jay-greco.com/wp/?p=147
    I just discovered that the click of the scroll wheel switches layers when routing.  The "follow-me" being slow is a more important issue anyways.
