EAGLE User Support (English) First schematic: IC not in library?
  • Views 605 views
I'm about to draw my first schematic, but the IC is not in the library!
The IC I'm using is a DIL40 PIC18F4520. The library has a PIC18F4550 which
has a similar layout for most pins.
What is the best plan??
Nigel M
If my question is about apples, please don't suggest bananas
    autodeskguest over 10 years ago in reply to quantasonics
    Am 09.09.2016 um 04:11 schrieb Gary Nelson:
    I'm dealing with similar issues.
    I don't find any COPY TO LIBRARY function by right click or any other means
    There is COPY, but that seems not to do anything. It does not ask for a destination, nor does it offer a PASTE or equivalnet operation
    My GUI does not seem to match what is described in the documentation
    https://www.element14.com/community/message/205390
    Target library must be open.
    Joern Paschedag
  • quantasonics
    quantasonics over 10 years ago in reply to autodeskguest
    Congrats, you have the chance to edit your first library, which is the
    other half of layouting image
    Check the manual in the doc directory. What I would do:
    1. From the Control panel(cp) create a new library (lib)and leave it OPEN.
    2. In cp go to the desired lib, rightclick the device you want to modify
    and select "copy to library". (Repeat with other packages / devices).
    3. Save your new lib.
    4. In the new lib EDIT the pin NAMES of the symbol according the datasheet.
    5. CHANGE the DIRECTION of pins (I/O, in, out etc) according datasheet.
    6. Rename the symbol.
    7. Create a NEW device and name it.
    8. ADD your new symbol to the device.
    9. With "New" (bottom right) select a package for that device.
    10. CONNECT the Pins of the symbol to the Pads of the package.
    11. Save the lib and close it. With USE (your lib) you have the lib
    available in your schematics.
    If that is your first own library, I would do it with an eight pin
    fantasy device first, to understand the handling.
    And do not forget, there is allways the F1 key image
    Gruß
    Jörn
    On Fri, 07 Nov 2008 14:45:35 +0000, Nigel Molesworth
    Panic over, found one on the download page. Out of interest though ...
