EAGLE User Support (English) How can I change the default libraries Eagle uses on startup?
  • Subscribers 177 subscribers
  • Views 762 views
  • eagle
  • settings
I recently "upgraded" to eagle 6 for OSx.  I find that it crashes a LOT.  Everytime it crashes it restores seemingly default settings for routing, grid settings, which libraries it uses, etc.  Is there a way to change these settings?  In particular I only use something like 10 libraries and hate having to click every single one I don't want (I'd rather not delete because you never know what you might want in the future).  I also would like the default grid in mm, defualt routing settings to what I like etc.  Any thoughts on how to do this?  If eagle doesn't crash it appears as though my previous settings are restored...unfortunately it seems that it crashes more often than not.  Thanks!
D
    0 autodeskguest over 12 years ago
    Thanks!
    D
    http://www.element14.com/community/message/87734#87734
    Hi David,
    First off, if you have Conduit installed on your machine, please remove
    it. We recently discovered that it raises total heck on EAGLE. That
    should improve the crashing situation considerably.
    Second, one of the best ways to setup defaults is to set them up in the
    eagle.scr file which runs every time you open an editor. Section 5 of
    the EAGLE manual covers its use in detail.
    Best Regards,
    Jorge Garcia
