EAGLE User Support (English) Problem routing (eagle and freeroute)
  • Subscribers 178 subscribers
  • Views 491 views
  • freeroute
  • eagle
  • violations
  • pcb
  • routing
Hi all.
I'm doing my first circuit in Eale, and when I'm doing the routing I use freerouter in order to autoroute. The thing is, once I've completed the process at freeroute and I execute the script, I can see what I think are some mistakes that violate pcb designing rules, which you can see on the bottom part in the image attached. How can I solve it?
Thanks for your help,
Javier
P.S. In the schematic I used net and junction to joint parts.
    Hi.
    If you don't mind, do it once more and set TOP LAYER N/A.
    Mogens.
    0 Former Member over 12 years ago in reply to Former Member
    Here is a new image, processed again with freeroute. In the hole number three it is possible to see the error
    You mean we see a part of the trace in hole #3? Don't worry it is gone when print the board.
    Mogens
