EAGLE User Support (English) Creating Multiple Parts in a Single Device
  • Subscribers 178 subscribers
  • Views 300 views
I would like to understand how to create multiple parts for a single device.  Exactly like the rcl.lbr is configured.  In the rcl.lbr, when I select C-US, there are multiple devices all with it own package.
How do I re-create this in my own library?  I want to make multiple parts for a single device, like resistors.
If someone can point me in the right direction or tutorial that would be great.
Mike
  • dukepro
    0 dukepro over 12 years ago
    On 09/09/2013 09:56 PM, Michael Steffen wrote:
    great.
    What you're looking for is multiple packages for a single device.
    Recall that a device associates one or more//_symbols_ with one or more
    packages.  Examining the device editor screen, the top left pane
    contains the schematic symbols.  The bottom left pane contains a
    description of the device.  The bottom right pane contains all the
    variants of the device, each variant being a separate package.
    In the bottom right panel, click on "New", choose a package, and give it
    a variant name.  Then click on "Connect" to connect the pins on the
    symbol to the pads on the package.  If you haven't already, give the
    device a Prefix character or string - each time a device is added to a
    schematic, Eagle will append a 1, 2, 3, ... to the prefix.
    I believe the key that may have been overlooked is giving each package a
    different variant name.  For simple devices, like R's and C's, I provide
    a name of "-0603", or "-0805", just so that the package shows up in the
    schematic.  For more complicated parts, like microprocessors, I set the
    variant name to the suffix from the part's datasheet designating the
    package.  For instance, 'N' for DIP packages.  In the schematic, the
    device appears as the device's name concatenated with the variant name.
    For more information, refer to the Eagle User Manual in Chapter 4.4.  In
    the English version of 6.5, start at the bottom of page 79.  I would
    also read Chapter 18 in the Tutorial, in particular starting at the
    bottom of page 63 in the English version of 6.5,
    HTH,
        - Chuck
    8508.att1.html.zip
