EAGLE User Support (English) Dimension and Drill Distance DRC Errors
  • Subscribers 183 subscribers
  • Views 336 views
I'm using the SEEED DRC file for my board and I have a custom part I created based off of this Dual Entry header: http://www.gradconn.com/2-54mm/pdf/BB02-JG.pdf
I get Dimension errors on layer 1 between every drill hole and SMD pad.
I also get Drill Distance errors between holes/pads 3 and 6.
I understand why the Dimension DRC errors are being generated - the distance between pad and hole is <7mil and the DRC file has a min of 10mil.  Since this is the recommended layout for the part, is there anything I can do about this other than pulling the pads back?
I also understand that the Drill Distance error is for a similar reason, but I don't understand why it's only happening on 2 pad/hole pairs when all the pairs are spaced the same.
Thoughts?
