EAGLE User Support (English) Circulair PCB
  • Replies 9 replies
  • Answers 2 answers
  • Views 1348 views
  • pcb
Circulair PCB
Hi Jorge.
I have to desgin a round PCB with 32pcs 3mm LED's on the outer side in a circle.
The diagonal size is 65 mm.
How do i get this circle devided in 32 simulair parts?
How do i rotate a component (shape) in degrees?
I'm running Eagle 6.4.0
Thanks in advance.
Ruud Rensen
    0 autodeskguest over 12 years ago in reply to autodeskguest
    Hi
    This is really easy to do it.
    I am a professional Printed Circuit Board manufacturer.We offer all
    kinds of PCBs.
    If you are intested in our products.Please feel free to contact me.
    Tom
    tom@unitpcb.com (mailto:tom@unitpcb.com)
    www.unitpcb.com
    http://www.element14.com/community/message/113418
    Am 14.05.2014 18:45, schrieb Jorge Garcia:
    On 9/24/2013 7:23 AM, Ruud Rensen wrote:
    Hi Jorge.
    circle.
    Thanks in advance.
    Ruud Rensen
    Hi Ruud,
    You could in addition to Chuck's suggestion try out the
    component-array.ulp that is up on the website.
    hth,
    Jorge Garcia
    cmd-draw.ulp?
    Joern Paschedag
    Hi Jorge.
    circle.
    Thanks in advance.
    Ruud Rensen
    Hi Ruud,
    hth,
    Jorge Garcia
  • dukepro
    0 dukepro over 12 years ago in reply to dukepro
    One correction below:
    On 05/14/2014 09:15 AM, Chuck Huber wrote:
    • Program to produce an Eagle script to position
    • a number of LED's in a circle about a point.
    int LED_COUNT = 32;
    // Dimensions are in mm and degrees
    // Center of circle
    real CENTER_X = 20.0;
    real CENTER_Y = 20.0;
    // Radius of circle
    real RADIUS = 20.0;
    real ARC_STEP = (360.0 / LED_COUNT);
    string exitScript;
    string tmp;
        int led;
        sprintf(tmp, "Grid mm;\n");
        exitScript += tmp;
        sprintf(tmp, "Mark (%.2f %2.f);\n",
    The second format specified should be "%.2f" instead of "%2.f".  This
    one slipped by.  Sorry.
            CENTER_X, CENTER_Y);
        exitScript += tmp;
        for (led = 0; led < LED_COUNT; ++led) {
            sprintf(tmp, "Move LED%d (P%.2f %.2f);\n",
                led + 1,
                RADIUS,
                ARC_STEP * led
            exitScript += tmp;
            sprintf(tmp, "Rotate =R%.2f 'LED%d';\n",
                ARC_STEP * led,
                led + 1);
            exitScript += tmp;
        exit(exitScript);
    // vim: set ts=4 sw=4 et ai:
  • dukepro
    The ULP version is below.
    HTH,
        - Chuck
    On 05/14/2014 09:03 AM, Chuck Huber wrote:
    On 05/14/2014 09:01 AM, Chuck Huber wrote:
    On 09/24/2013 07:23 AM, Ruud Rensen wrote:
    Hi Jorge.
    circle.
    For this many LED's it's easy to write a program to produce a script.
    Attached is a program written in C that will do this.
    I might also add that this could very easily have been done in a ULP
    rather than a C program.
    int LED_COUNT = 32;
    // Center of circle
    // Radius of circle
    real RADIUS = 20.0;
    string exitScript;
    string tmp;
        int led;
        exitScript += tmp;
        exitScript += tmp;
                led + 1,
                RADIUS,
                ARC_STEP * led
            exitScript += tmp;
                ARC_STEP * led,
                led + 1);
            exitScript += tmp;
        exit(exitScript);
  • dukepro
    Hi Jorge.
    circle.
    HTH,
        - Chuck
  • dukepro
    Hi Jorge.
    circle.
    Attached is a program written in C that will do this.  Also attached is
    the Eagle script that this program produces.  The radius is a bit small,
    but it's good enough for demonstration.  Adjust the center point and the
    radius of the circle as necessary.
    Since this forum has problems with attachments making it to the web
    portal, I have included the source inline.
    C Program:
    #include <stdio.h>
    #define LED_COUNT   32
    // Center of circle
    #define CENTER_X    20.0
    #define CENTER_Y    20.0
    // Radius of circle
    #define RADIUS      20.0
    #define ARC_STEP    (360.0 / LED_COUNT)
    int main() {
        int led;
        printf("Grid mm;\n");
        printf("Mark (%.2f %2.f);\n",
            printf("Move LED%d (P%.2f %.2f);\n",
                led + 1,
                RADIUS,
                ARC_STEP * led
            printf("Rotate =R%.2f 'LED%d';\n",
                ARC_STEP * led,
                led + 1);
        return 0;
    The Eagle script generated:
    Grid mm;
    Mark (20.00 20);
    Move LED1 (P20.00 0.00);
    Rotate =R0.00 'LED1';
    Move LED2 (P20.00 11.25);
    Rotate =R11.25 'LED2';
    Move LED3 (P20.00 22.50);
    Rotate =R22.50 'LED3';
    Move LED4 (P20.00 33.75);
    Rotate =R33.75 'LED4';
    Move LED5 (P20.00 45.00);
    Rotate =R45.00 'LED5';
    Move LED6 (P20.00 56.25);
    Rotate =R56.25 'LED6';
    Move LED7 (P20.00 67.50);
    Rotate =R67.50 'LED7';
    Move LED8 (P20.00 78.75);
    Rotate =R78.75 'LED8';
    Move LED9 (P20.00 90.00);
    Rotate =R90.00 'LED9';
    Move LED10 (P20.00 101.25);
    Rotate =R101.25 'LED10';
    Move LED11 (P20.00 112.50);
    Rotate =R112.50 'LED11';
    Move LED12 (P20.00 123.75);
    Rotate =R123.75 'LED12';
    Move LED13 (P20.00 135.00);
    Rotate =R135.00 'LED13';
    Move LED14 (P20.00 146.25);
    Rotate =R146.25 'LED14';
    Move LED15 (P20.00 157.50);
    Rotate =R157.50 'LED15';
    Move LED16 (P20.00 168.75);
    Rotate =R168.75 'LED16';
    Move LED17 (P20.00 180.00);
    Rotate =R180.00 'LED17';
    Move LED18 (P20.00 191.25);
    Rotate =R191.25 'LED18';
    Move LED19 (P20.00 202.50);
    Rotate =R202.50 'LED19';
    Move LED20 (P20.00 213.75);
    Rotate =R213.75 'LED20';
    Move LED21 (P20.00 225.00);
    Rotate =R225.00 'LED21';
    Move LED22 (P20.00 236.25);
    Rotate =R236.25 'LED22';
    Move LED23 (P20.00 247.50);
    Rotate =R247.50 'LED23';
    Move LED24 (P20.00 258.75);
    Rotate =R258.75 'LED24';
    Move LED25 (P20.00 270.00);
    Rotate =R270.00 'LED25';
    Move LED26 (P20.00 281.25);
    Rotate =R281.25 'LED26';
    Move LED27 (P20.00 292.50);
    Rotate =R292.50 'LED27';
    Move LED28 (P20.00 303.75);
    Rotate =R303.75 'LED28';
    Move LED29 (P20.00 315.00);
    Rotate =R315.00 'LED29';
    Move LED30 (P20.00 326.25);
    Rotate =R326.25 'LED30';
    Move LED31 (P20.00 337.50);
    Rotate =R337.50 'LED31';
    Move LED32 (P20.00 348.75);
    Rotate =R348.75 'LED32';
    circle.
    polar coordinates?
    see online help 'Editor Commands - Command Syntax'
    Lorenz
    0 shabaz over 12 years ago
    Hi Ruud,
    This is easy to do using a script; for example if your LEDs are designated D1-D32, then D1 can be moved using:
    MOVE D1 (x y)
    where x and y are the co-ordinates
    Rotation:
    ROTATE Rz D1
    where z is the angle in degrees.
    You could create the script (text file) manually or using software.
