EAGLE User Support (English) Draw Label Problem
  • Subscribers 177 subscribers
  • Views 240 views
Draw Label Problem
Greetings,
Using Eagle for a few hours and I have found a problem I can's solve. When adding a label to a net, sometimes it is autogenerated e.g "N$3", and then I can change it. However, sometimes it uses a previous label, which is no good as when I change it all occurrences of that label change as well. What am I doing wrong?
    0 autodeskguest over 12 years ago
    a label is always attached to a net. When you select the label command
    and then click on a net stub the label reflects the name of that net.
    if you just want to place some text not related to a net then use the
    text command.
    Lorenz
