EAGLE User Support (English) XML format for libraries
  • Subscribers 180 subscribers
  • Views 1213 views
  • xml
  • libraries
Hi, since version 6.xx the libraries should have been converted to XML from the previous binary format...am I correct?
I use version 6.50, free edition, and all my projects and newly created libraries are still in binary.
I can not find in menus any chance to import/export/convert to XML.
What is wrong? Is there a setting somewhere or this feature is not available with the free version ?
P.S. this is my first post to the forum, so please forgive me if something is wrong.
I wanted to do a search inside the topics, but I can not find the classical "Search" field.
If it exists, where is it ?
    0 autodeskguest over 12 years ago
    Am 26.09.2013 10:14, schrieb Giacomo Alfandari:
    Yes.
    Just open your old library with Eagle Version 6.xx and save the library.
    You don't have to export/import/convert manually.
    something is wrong.
    http://www.element14.com/community/message/89972#89972
    Cheers Patrick
    0 Former Member over 12 years ago in reply to autodeskguest
    Thanks Patrick for your prompt reply.
    I'm quite confused!
    I use Eagle since version 4.something and in these years I created a lot of
    components.
    When a new release is available, I switch to it and then I move my own
    libraries in the new LIB folder.
    Most of these have been created with versions 6.xx, so they should already
    be in XML.
    Actually, when I open them with a text editor (Ultraedit), some are in XML
    and some are still in binaries.
    In example: in August 2012 I made an Analog Devices DDS library with about
    6 components (fresh, not copied).
    On that date I was for sure at release 6.3, eventually at 6.4, but the lib
    was still in binary.
    I opened the lib and then saved it without any modification...and
    'whoilà', it is now in XML!
    Does it mean that a newly created lib is formatted in binary and only
    re-saving it is converted?
    Confusing!
    EDIT:
    in the meantime, I made a test lib with just one pin...it has been coded in
    XML !? (even more confusing)
    I think this message does require an answer; it is only to let you know my
    feeling.
    Thanks anyway.
    library.
    The Answer is 42
    0 autodeskguest over 12 years ago in reply to Former Member
    I think by far the most likely explanation for all that you have
    observed would be that in August 2012 you were still using V4.x or V5.x
