EAGLE User Support (English) Designlink possible with Farnell (Europe) ordercodes?
  • Replies 16 replies
  • Subscribers 182 subscribers
  • Views 2687 views
Joop14
Joop14 over 12 years ago
I tried to use the Designlink button in Eagle but it seems to work only with Newark.
Because I'm located in Europe, is it possible to use Designlink with the Farnell database instead?
The ordercodes generated by Newark don't seem to be accepted by the Farnell (Europe) website.
Thanks in advance,
Joop
    Former Member over 11 years ago in reply to Former Member +1
    Hello Jean-Luc, you can find it here: https://gist.github.com/hollie/bc057d8c9ea3805e4f87 . Note however: I tried the modified script on another computer with another locale (and another OS) and it was…
    Former Member over 11 years ago in reply to autodeskguest +1
    Hi Jorge. Good Lord, why does which country we live in even matter? Isn't this just about accessing a database to identify the parts we want, or is it for actual ordering? I live in Norway, so yeah, guess…
    0 Former Member over 11 years ago in reply to Former Member
    Hello Jean-Luc,
    you can find it here: https://gist.github.com/hollie/bc057d8c9ea3805e4f87.
    Note however: I tried the modified script on another computer with another locale (and another OS) and it was not working there. So I'm not sure it will help you further. I did not debug it further. It would be cool if element14 people would have a look at this to fix it for everybody. Maybe ins tread of guessing the URL/server and currency from the system settings they could give users an option to select the settings before running the script?
    Best regards,
    Lieven.
    Hi Lieven
    Many thanks
    When I run the script I have dialog saying :
    Can't open '/Applications/EAGLE-6.5.0/fdlQuery.html'
    Permission denied
    I have created the file and also file:///Applications/EAGLE-6.5.0/fdlResponse.html
    so now the script runs but I have the same error as usual
    Error while accessing 'https://api.element14.com/pffind/services/SearchService':
    299 Error downloading https://api.element14.com/pffind/services/SearchService?callinfo.apiKey=sf4kqy6u29tkt95gg5a3wejz - server replied: Bad Request
    <h1>Bad Request</h1>
    btw here are the content of the 2 html files
    fdlQuery.html :
    <soapenv:Envelope  xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"  xmlns:v1="http://pf.com/soa/services/v1">
    <soapenv:Header>
       <v1:userInfo>
         <v1:signature>GHvMyPN967kFEJKtpJe2w11qMcA=</v1:signature>
         <v1:timestamp>2014-04-09T15:51:22.000</v1:timestamp>
         <v1:locale>fr_UK</v1:locale>
       </v1:userInfo>
       <v1:accountInfo>
         <v1:customerId>CadSoft2</v1:customerId>
       </v1:accountInfo>
    </soapenv:Header>
    <soapenv:Body>
       <v1:keywordParameter>
         <v1:keyword>DB15</v1:keyword>
         <v1:offset>0</v1:offset>
         <v1:numberOfResults>50</v1:numberOfResults>
          <v1:RefinementParameters>
            <v1:inStock>false</v1:inStock>
            <v1:rohsComplaint>false</v1:rohsComplaint>
          </v1:RefinementParameters>
        </v1:keywordParameter>
      </soapenv:Body>
    </soapenv:Envelope>
    and fdlResponse.httml :
    any other ideas ?
    Hi again
    I found this old post and guess what ... it worked !
    designlink.zip
    Hope this help
    (we need to have a look on the code he use ;-)
    0 Former Member over 11 years ago in reply to autodeskguest
    Hi Jorge.
    Good Lord, why does which country we live in even matter? Isn't this just about accessing a database to identify the parts we want, or is it for actual ordering? I live in Norway, so yeah, guess I will have to wait long and hard before I get to be included... Edited the script as described, but didn't work... Why exactly can't we just access Newark?
    0 autodeskguest over 11 years ago in reply to Former Member
    On 5/6/2014 12:51 PM, Eystein Orsnes wrote:
    Good Lord, why does which country you live in even matter? Isn't this
    just about accessing a database to identify the parts you want? I live
    The country matters because Designlink want to show pricing in your
    local currency. Setting the country code to the US code should allow you
    to check Newark's inventory.
    hth,
    Jorge Garcia
  • jo6466
    0 jo6466 over 9 years ago in reply to Former Member
    Hi Martin
    I found the solution
    Juste change this line as follow and all will work :
    string DISearchURL = "be.farnell.com"; // Unified to one URL since May 12
    Best regards
