EAGLE User Support (English) Designlink possible with Farnell (Europe) ordercodes?
  • Replies 16 replies
  • Subscribers 190 subscribers
  • Views 3109 views
Joop14
Joop14 over 13 years ago
I tried to use the Designlink button in Eagle but it seems to work only with Newark.
Because I'm located in Europe, is it possible to use Designlink with the Farnell database instead?
The ordercodes generated by Newark don't seem to be accepted by the Farnell (Europe) website.
Thanks in advance,
Joop
  • jo6466
    0 jo6466 over 9 years ago in reply to e14 Contributor
    Hi Martin
    I found the solution
    Juste change this line as follow and all will work :
    string DISearchURL = "be.farnell.com"; // Unified to one URL since May 12
    Best regards
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    On 5/6/2014 12:51 PM, Eystein Orsnes wrote:
    Good Lord, why does which country you live in even matter? Isn't this
    just about accessing a database to identify the parts you want? I live
    in Norway, so yeah, guess I will have to wait long and hard before I get
    to be included... Edited the script as described, but didn't work... Why
    exactly can't we just access Newark?
    The country matters because Designlink want to show pricing in your
    local currency. Setting the country code to the US code should allow you
    to check Newark's inventory.
    hth,
    Jorge Garcia
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Hi Jorge.
    Good Lord, why does which country we live in even matter? Isn't this just about accessing a database to identify the parts we want, or is it for actual ordering? I live in Norway, so yeah, guess I will have to wait long and hard before I get to be included... Edited the script as described, but didn't work... Why exactly can't we just access Newark?
    Hi again
    I found this old post and guess what ... it worked !
    designlink.zip
    Hope this help
    (we need to have a look on the code he use ;-)
    Hi Lieven
    Many thanks
    When I run the script I have dialog saying :
    Can't open '/Applications/EAGLE-6.5.0/fdlQuery.html'
    Permission denied
    I have created the file and also file:///Applications/EAGLE-6.5.0/fdlResponse.html
    so now the script runs but I have the same error as usual
    Error while accessing 'https://api.element14.com/pffind/services/SearchService':
    299 Error downloading https://api.element14.com/pffind/services/SearchService?callinfo.apiKey=sf4kqy6u29tkt95gg5a3wejz - server replied: Bad Request
    <h1>Bad Request</h1>
    btw here are the content of the 2 html files
    fdlQuery.html :
    <soapenv:Envelope  xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"  xmlns:v1="http://pf.com/soa/services/v1">
    <soapenv:Header>
       <v1:userInfo>
         <v1:signature>GHvMyPN967kFEJKtpJe2w11qMcA=</v1:signature>
         <v1:timestamp>2014-04-09T15:51:22.000</v1:timestamp>
         <v1:locale>fr_UK</v1:locale>
       </v1:userInfo>
       <v1:accountInfo>
         <v1:customerId>CadSoft2</v1:customerId>
       </v1:accountInfo>
    </soapenv:Header>
    <soapenv:Body>
       <v1:keywordParameter>
         <v1:keyword>DB15</v1:keyword>
         <v1:offset>0</v1:offset>
         <v1:numberOfResults>50</v1:numberOfResults>
          <v1:RefinementParameters>
            <v1:inStock>false</v1:inStock>
            <v1:rohsComplaint>false</v1:rohsComplaint>
          </v1:RefinementParameters>
        </v1:keywordParameter>
      </soapenv:Body>
    </soapenv:Envelope>
    and fdlResponse.httml :
    any other ideas ?
    Hello Jean-Luc,
    you can find it here: https://gist.github.com/hollie/bc057d8c9ea3805e4f87.
    Note however: I tried the modified script on another computer with another locale (and another OS) and it was not working there. So I'm not sure it will help you further. I did not debug it further. It would be cool if element14 people would have a look at this to fix it for everybody. Maybe ins tread of guessing the URL/server and currency from the system settings they could give users an option to select the settings before running the script?
    Best regards,
    Lieven.
    Hi Lieven,
    Can you post your designlink-inc.ulp for Belgium ?
    I modified it according you suggestion but It doesnt work for me
    many thanks in advance
    Jean-Luc
    A follow-up: when I change the country information line of 'UK' to
       "UK EUR 0 be.farnell.com",
    and set DIcountry = "UK"
    Then the designlink process seems to work.
    0 e14 Contributor over 12 years ago in reply to jensvanhoof
    Jens,
    I am experiencing the same problem you have. I got the script to recognize the correct country by copying the 3 designlink ULP files to a separate folder, then making the change to desiglink-inc.ulp
    DIcountry = "BE";
    (Note, making the change to 'language' does not seem to work).
    Then run the script designlink-order.ulp from the folder you copied the scripts to. The script then at least tries to connect to the service defined for Belgium. I verified this by adding a debug print statement in the designlink-inc.ulp InitCountryData function.
    Unfortunately I then get an error:
    299 Error downloading https://api.element14.com/pffind/services/SearchService?callinfo.apiKey=<snip> - server replied: Bad Request
    So apparently this functionality is broken for Belgium. You can get it partially working by changing the DIcountry to "UK", note that you get price in pounds then but at least the order codes seem to be correct.
    @jorge can you please check why designlink is not working for country code "BE"? I guess there is some configuration on the API server that does not allow request with the country code "BE".
    Kind regards,
    Lieven.
    Hi Jorge,
    I'm having exactly the same problem here. All options have been tried but I cannot get into the Dutch ("NL") Farnell store. Only into Newark.
    Any further suggestions on how to solve this?
    Martin
