EAGLE User Support (English) How do I delete the wires in a layer by ULP?
  • Subscribers 178 subscribers
  • Views 723 views
  • ulp
fabiodl
fabiodl over 12 years ago
I am new to ULP.
I can count how many wires there're in a layer by this code
int i=0;
string buff;
board(B) {
  B.wires(w) {
    if (w.layer==46){
      i++;
sprintf(buff,"%d wires",i);
dlgMessageBox(buff);
What I would like is deleting the wires of layer 46 by a ULP. Is there any built in function for that? Something like
  delete(w)
If it is not possible, what other approach could I use to delete the content of a layer programmatically?
    autodeskguest over 12 years ago +1
    On 08/10/13 15:52, Fabio DL wrote: What I would like is deleting the wires of layer 46 by a ULP. Is there any built in function for that? Something like delete(w) ? If it is not possible, what other approach…
    autodeskguest over 12 years ago in reply to fabiodl +1
    On 09/10/13 17:54, Fabio DL wrote: Thank you, I tried looking at scripts. Still I didn't progress much. DISPLAY NONE 46; GROUP ALL; but then DELETE *, DELETE ALL or DELETE GROUP do not seem to exists.…
    0 autodeskguest over 12 years ago
       delete(w)
    ULPs are a bit... unexpected in that there are no facilities in the
    language for making any change at all to the design. You just can't.
    However, you can do something after the event. If your ULP passes a
    string to the "exit" function on completion, then Eagle will execute
    that string as if you'd typed it in the command box. So either
    accumulate all your deletion commands into a string and end with:
       exit(cmd);
    or write them to a script file and end with:
       exit("SCRIPT '" + scriptfile + "';");
    There are examples of both in the ULPs supplied with Eagle.
  • fabiodl
    0 fabiodl over 12 years ago in reply to autodeskguest
    DISPLAY NONE 46;
    GROUP ALL;
    but then DELETE *, DELETE ALL or DELETE GROUP do not seem to exists. Do you know any command that serves the purpose?
    0 autodeskguest over 12 years ago in reply to fabiodl
    DISPLAY NONE 46;
    GROUP ALL;
    http://www.element14.com/community/message/91037#91037
    Check the help, under "Editor Commands -> Command Syntax"
    If you were doing this operation by hand, you would set only layer 46
    shown, select the group tool and sweep over the whole lot. That much you
    have done. Then you would select the delete tool and click the right
    mouse button (with the control key if you're on the V5 user interface -
    I'm still mostly using V4.15) anywhere on screen.
    That help page explains the syntax, but for "delete tool
    ctrl-right-click" you want:
    DELETE (C> 0 0);
  • fabiodl
    Thank you, sorry I didn't notice it.
