EAGLE User Support (English) No pins on net N$2
  • Subscribers 180 subscribers
  • Views 562 views
  • erc
  • net
  • error
No pins on net N$2
ngmeagle
ngmeagle over 12 years ago
Eagle gives no further explination or recomendation to solve this.  It also does not list a sheet number next to this warning.
Double clicking the error or using the centered check box does not zoom in on the relevant part of the schematic.
What steps can I take to resolve this issue?
-ngm
    0 autodeskguest over 12 years ago
    In my experience it should center and highlight the net.
    What about "show N$2"?
    Marco
  • dukepro
    0 dukepro over 12 years ago
    -ngm
    Try "show @ N$2".
    If it's not a multi-sheet schematic, add a second sheet, select it, then
    issue the above command.  A dialog box will pop up telling you that N$2
    is on sheet 1.  Double click it and the window will zoom to the extent
    of N$2, and draw a bounding box around it.
    HTH,
        - Chuck
    0 autodeskguest over 12 years ago in reply to autodeskguest
    Marco
    Or try  SHOW @ N$2
    Richard Hammerl
  • ngmeagle
    0 ngmeagle over 12 years ago in reply to autodeskguest
    I tried both SHOW N$2 and SHOW @ N$2 and nothing happens, the schematic doesn't recenter, it doesn't highlight anything.  It only says the following at the bottom of the page Net: N$2, Class: 0 default Left-click to select object to show (or type object name)
    NGMEagle
    Marco
    Or try  SHOW @ N$2
    Richard Hammerl
