EAGLE User Support (English) Making a Top and Bottom heatsink w/connecting mounting holes.
  • Subscribers 178 subscribers
  • Views 389 views
  • board
  • pad
  • eagle
  • pcb
  • pour
  • layer
  • polygon
dta116
dta116 over 12 years ago
I need a heatsink on both sides of a board connected by 3 mounting holes. They need to be either bare solder or bare copper (probably polygons). I cannot understand how to do define the polygons to be bare or solder with no masking and include the through holes connecting the top and bottom sides.
Thank you for your support.
    0 autodeskguest over 12 years ago
    http://www.element14.com/community/message/91337#91337
    Add polygons to mask layers.
    One thing is that shiny unmasked pcb has a lower emissivity then the
    solder mask coating.
    You should only remove the mask where you are mounting the tab or heat
    sinks to the PCB.
    Paul R
