EAGLE User Support (English) drill hole clearance - giving DRC dimensios error - how can i fix it
  • Subscribers 189 subscribers
  • Views 1221 views
Hi
I'm getting dimension errors on my board on DRC, but i can't understand why because the hole on the component package is 9mm of diameter and this on the PCB corresponds to the small centered circle, however this dimension on the PCB is extended with the two triangles and is over the pads causing an error.
How can i fixe this?imageimage
  • dukepro
    0 dukepro over 12 years ago in reply to e14 Contributor
    On 10/21/2013 04:52 PM, Eloi Carvalho wrote:
    On the tab - distance, i had already changed drill/hole to zero, but
    didn't fix the error, and i have now changed the copper/dimension to
    23mil an it fixed the error ( by default was 40mil), and 24mil is in
    fact the distance from the circle to the pad.
    Eloi,
    Check your board house's capabilities.  They can usually get routing to
    within 5 mils and drilling to within 2 or 3 mils.  I usually set the
    copper/dimension to 10 to 15 mils.
        - Chuck
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    On the tab - distance, i had already changed drill/hole to zero, but didn't fix the error, and i have now changed the copper/dimension to 23mil an it fixed the error ( by default was 40mil), and 24mil is in fact the distance from the circle to the pad.
    0 autodeskguest over 12 years ago
    Hi
    The two triangles are simply the symbol for that hole size so ignore them
    The issue is with your DRC settings. There is a setting that specifies the
    minimum distance between a hole and a pad so change that to less than the
    distance between the hole and the pad.
    As an aside. Eagle has not changed to reflect the reducing geometries of
    parts and designs so the default setting need changing.
