EAGLE User Support (English) Problems with Eagle since upgrading to OS 10.9
  • Subscribers 180 subscribers
  • Views 462 views
JHV3
JHV3 over 12 years ago
Hello all,
Has anyone encountered and or found a fix for Eagle instability in Mavericks?
Two things are happening consistently:
- The move tool in schematic capture no longer shows the part/line/item etc in motion (screen is not updated with mouse moves). The instance simple drops at the cursor whenever you click.
- The program crashes when trying to add libraries to use.
I thought a fresh install may help but I get this:
Anyone have any ideas?
Thank you in advance!
    0 autodeskguest over 12 years ago
    Jack Vaughan wrote on Fri, 01 November 2013 22:24
    Hello all,
    Mavericks?
    part/line/item
    I can confirm this happens to me too.  If you switch to another window
    (CMD+tab) and then switch back, the display is updated and works as normal.
    It's annoying and should be fixed, but switching windows gets you going
    now.
    That one I can't reproduce.  How are you adding libraries to be used?
    Cheers,
    James.
    http://www.element14.com/community/message/93682#93682
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
  • JHV3
    0 JHV3 over 12 years ago in reply to autodeskguest
    James,
    Thank you very much for the tip using CMD+tab. What a relief!
    As far as the "use" library menu crashing the system, since the original post I think it may have been a compatibility issues with the specific .sch file I was using (it was created on a PC using an earlier release, not sure which one yet).
    After creating a new file and redrawing the .sch I've had not problem adding libraries to be used.
    Thank you again James! You've been very helpful.
  • Radiocode
    0 Radiocode over 12 years ago
    Jack,
    Installing OSX 10.9 has reset your security preferences, and OSX is preventing you from installing an unverified package.
    You can either select "Allow apps downloaded from: Anywhere" within your System Preferences, or just ctrl-click the package and select "Open" to install it without having to change your preferences.
    That should allow you to reinstall Eagle if you need to.
    Lee
  • JHV3
    0 JHV3 over 12 years ago in reply to Radiocode
    Lee,
    Thank you very much. This worked for me immediately, and is very useful to know.
    I appreciate your reply!
    Jack
  • CSWalt
    0 CSWalt over 12 years ago
    On 11/02/13 03:30, Jack Vaughan wrote:
    Hello all,
    Mavericks?
    Running EAGLE on OSX 10.9 should normally work
    but we don't support it officially yet, because our 3rd party graphics
    libraries don't support it yet.
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
