EAGLE User Support (English) Replace device in schematic and board
  • Subscribers 177 subscribers
  • Views 1933 views
Is it possible to replace a device (symbol &
package) with a identical device from a different
library?
I have tried "replace" command, but it only brings
up the standard Eagle library; my target device is
  in a personal library.
How do I direct the "replace" pop-up window to my
library?
Thank for any help........Jeff
    Uman wrote:
    Is it possible to replace a device (symbol & package) with a identical
    device from a different library?
    I have tried "replace" command, but it only brings up the standard Eagle
    library; my target device is  in a personal library.
    How do I direct the "replace" pop-up window to my library?
    Read about the command use
    Type "help use"  in eagle command field.
    For example "use your.lib"
    Or in control panel right click your lib and select use.
    library?
    library?
    Control-DEL to delete your old part from the schematic.  Then "use"
    your personal library and "Edit/Add" the part from your personal
    library.  Assuming that the new part has the same symbol as the old
    part, the new part should get connected to the same nets as the old
    part.
    HTH
    -Dave Pollum
