EAGLE User Support (English) Stop Mask errors
  • Subscribers 179 subscribers
  • Views 345 views
Stop Mask errors
What exactly is a stop mask error and is it important or can I ignore
it.  It seems to be mostly silk screen related.
   Z.K.
  • Richard_H
    Richard_H over 17 years ago
      Z.K.
    From the manual:
    If there are silkscreen objects drawn in layers 21, 25, 27 for
    components on the Top  layer, and  22,  26,  and 28 for components
    on the Bottom  layer overlapping the area of a solder stop symbol
    generated in layer 29 and 30, the DRC reports a Stopmask error.
    You have to display the corresponding layers to activate this check!
    Please keep in mind that this check always takes the vector font
    as basis for the   calculation   of   the   required   space.
    This   is   the   font   type   the   CAM Processor uses
    for manufacturing data generation.
    Richard Hammerl
      Z.K.
    From the manual:
    OK, thanks.
        Z.K.
