EAGLE User Support (English) how do you create pads with an oval slot hole?
  • Subscribers 178 subscribers
  • Views 2154 views
I'm trying to create PCB footprints for some parts that use an oval shape
slot hole for snap-in mounting.
The standard pad menu only seems to offer circular holes.  How can I define
an oval slot-type cut?
Thanks!
-Justin
    shape slot hole for snap-in mounting.
    define an oval slot-type cut?
    Thanks!
    -Justin
    Maybe the first question is: how will your board house make these oval
    holes ?
    Probably need a milling process, in which case you could put a pad and
    then mill in the middle of it ?
    John G.
    Thanks!
    -Justin
    holes ?
    John G.
    ...and if so the manufacturer need one gerber with milling traces to
    mill before plating (metallised holes), and one to mill after plating
    (non-metallised holes) if you have holes/slots of both types.
    Thanks!
    -Justin
    I had to create oval holes in a project at work though I was using
    Altium and not Eagle.  What I did was overlap three holes so it looked
    like an oval shape.  The board house we used was Prototron Circuits and
    they seemed to know what I wanted though they did call and ask just to
    be sure.  Anyway, you might try that though not all board houses will do
    oval shapes especially the cheaper ones.
        Z.K.
    Hmm, well I haven't really chosen a board house.  I suppose they way I'd
    want to implement it is whatever is cheapest and most widely supported at a
    variety of board houses.
    I have the datasheet here if anybody wants to see what I'm talking about:
    http://www.equinoxsystems.net/usb_connector.pdf
    Is adding a poly with arc endings to the mill layer the right way to do
    this?  Can this sort of cut be done with some sort of router bit that could
    go all the way through the board?  This seems like it would be a fairly
    common problem, anybody have suggestions on what they've done in similar
    situations?
    "Justin Jones" <justin@techix.com> wrote in message
    news:ggcjqi$mb9$1@cheetah.cadsoft.de...
    Thanks!
    -Justin
    Thanks!
    -Justin
    like an oval shape.
    Caution /!\ Risk of breaking the drills if they actually drill on edge
    of previous hole.
    be sure.
    I guess they changed the holes to a milled trace themselves?
    Morgan Leijström pravi:
    Thanks!
    -Justin
    like an oval shape.
    of previous hole.
    be sure.
    This is usual practice...
    If manufacturer see the overlaping drill they change this to mill path.
    At least if the drill is under 1mm thick. If the drill is 2.5mm or more
    they just use it. (it wont broke) If drill is im midle of that they
    usaly contact customer.
    s.
